Wrong. If it's not a direct replacement, drop in unit, the customer needs to know. There's nothing in the SHOSource listing that says it'll require modification to install, or that it won't look exactly like the stocker, but will fit and perform just fine.
FWIW, Summit sells the 526 pump only, and 526-1 kit, if someone wants to order an exact drop in replacement.
Up till now it has not been an issue but it can be corrected.
We will be offering the direct drop in.
They should. It is in their interest not to have to deal with after sales support when they can avoid it. And if their picture shows the stock pump and not the one they sell then they need to fix that.
This whole sentence should be removed too, especially since Walbro made the stock pumps:
And the last sentence in the description doesn't jive with the quote above:
The end of the description should just say "Good luck!"![]()
ese particular pumps have been used for years with no problem. I have installed a couple them myself.
The stock pump is in refrence to SLO pumps that flow only 60.
That is a requirment by Walbro due to people sending pumps that do work.
I ordered a 155LPH walbro from SHOsource and installed it no problems, no bending, no forcing what-so-ever. I didn't even need borrow any **** from Bab.
