Slight hesitation
It's SHO Time
Gillette, Wyo
I think i have noticed a slight hesitation when my rpms are around 3200 and up to 3900 before the secondaries open. I do have oil in my plug wells but I suck all the oil out of them weekly untell i plug a hose right before the intake runner, but any way, I have stock plug wires and mayabe stock plugs (not sure i'm the 3rd owner, and the 2nd owner is my best friend and he didn't change them), do you guys think it is my plug wires and plugs or something else...
thanks for all the help,
Justin
Ishodu
I think you may need some maintance. The plugs and wires and new seals will help you out but it may not be the problem, but it aint going to hurt anything. You might want to check your codes and see what you find there and take care of them if there are any. I know its not easy being 16 and spening alot of money but it seem to be required with these cars.
It's SHO Time
Gillette, Wyo
I'm not worried about cash, I just ran my codes and only got 111 which means systems check ok, right? I order some taylor 8mm plugswires and some motorcraft plugs.
Ishodu
Make sure you get the right wires alot of them don't seal up good just do a search on plug wires and there will be lots of info. Also your going to have to get the oil in the plug wells problem fixed.
It's SHO Time
Gillette, Wyo
i got the oil in the plug wells fix with a temp. fix by pluging that hose tell it gets warm here for me to do the 60k on her, i did a search and people told me get either taylor wires or motorcrafts. thanks for all the help man,
Justin
David Carpenter
