Personally, I think since running the slicks I've been easier on the car. With low pressure in the tires, it's very "un-dramatic" when you leave the line. With the wheel hop prone radials (I've run nitto's and BFG DR's), you feel like you are beating on the car more with the radials. You can be as easy or as ******* the car as you want with the slicks, but with FWD and bad rear weight transfer, they'll still spin when you shock them off the line. The advantage of them is once they hook up, they don't let go again. So just pin it WOT in 1st gear, and they stay with you all the way. No wheelspin, even when the "juice" hits.
But with just a few lbs of air in the fronts, and the floppy sidewalls, the car is sorta "dancy" on the big end @ 110 mph. You gotta stay up on the wheel to keep it pointed straight.
