Side markers and window washer
Eliw
Brooklyn NY
Ok, so a few days ago, I ran out of washer. I had hit it a few times till I noticed the low washer light come on. I filled it up a few days later and now I've got nothing. Fuses are ok and the wipers work. The washer pump doesnt even come on. When I went to check the washer bottle (you know jiggle it a little) I also noticed that My side marker lights werent on even though the headlights were on. All the lights except those were on.
So here's the thing...... About two days after I ran out of washer fluid, I messed around with the fog light switch trying to do the mod thing for the fog lamps. This didnt work because I have an 89 whose fog light switch connector is not the same as the other years. I tried to do it anyway and put some cables together to see if it would work. I did this in a few combinations but it never worked. I put the cables back the way they were, taped them up and reinstalled the switch. During this process, I did blow a few fuses.
To get to the point....... Does anybody know what the **** I screwed up? Also, does anybody know how I could get my side markers back and my washer motor to come on?
Thanks I would really appriciate it.
