SHOrt Shifter Installed!!
rktmn
Well-Known Member
miami
You are welcome Kenny.
I am glad you you like it. You might want to consider the Delrin bushing and the clervis pin upgrade. It will take out all the slop at the transmission input shaft, and tighten the shifts even more.
Jose
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Jose
You know, I was just talking to K dawg over the weekend and this came up. Whats the bushing and pin run from you? I forgot about these and I would have added them to the shifter purchase.
jayro
Auburn, In
I keep hearing great things about the SHOrt shifter. Im really starting to think I need one of these.
StAnGbAnGeR
NavistarEngTec
Homer Glen, IL
I'm thinking I need one too. Hopefully I really start kicking **** at the new position at work......one bonus check that the wifey doesn't know about will cover it.
rktmn
Well-Known Member
miami
Kevin, if you are having problems finding the gears at first, raise the handle so the shifts wont be too close to each other. You will also have more leverage,
As ypou get used to it, you can lower the handle to get the full short shifts.
Jose
