shock and strut replacement front and rear
aggiesho
Houston, Texas
Are the front and rear Sensa-Trac struts from Napa the correct ones to buy?
this is what the site says
Attributes:
Body Length:14.625"
Compressed Length:14.750"
Extended length:21.125"
Parts Pack(s) #:p590
Rod Nut #:Included in parts pack
Travel Length:6.375"
also what difficulities might i run into while replacing them that i can look for now.
Green Sho
Agawam, MA
i would suggest strut mounts and bearings as well...and if your springs are saggy i would also replace those. I do believe those will work, ive never used those before so i couldnt tell yah how they are.
aggiesho
Houston, Texas
cool thanks. if i replace everything at once w/ thoes ones i wont need a spring compressor will i?
Aaron R.
Rochester, New York
Dont break the pinch bolt. You might not have a problem from Texas but if it gets hard to loosen, tighten it back up a couple of times to work it loose. You do NOT want to break it!
Aaron
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I almost thought about buying those to use for a little while, just after adding the mounts, bearings, spring seats, wasn't too much more for the coils and struts.
JustInSideThG8s
Orange CA
Aaron
i didnt break it but haynes says to replace it everytime its taken off... anyone have a part number so i can get a couple from az or kragen...? same with the nuts on the stabilizer bars... i had to dremel one of them off they were so difficult...
or just measurements and type on the bolts and nuts and i should be able to figeure them out....
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
AK 50 / and AK 52 some places for the bolt and nut. I think those are NAPA numbers, Rock auto numbers, and autozone numbers. Not positive tho.
