sho wont run
tfalconier
CT
i have a 90 sho, its got 98,000 miles on it, 5 speed, its been sitting for a while, the 02 sensor used to be disconnected, and it used to start up and run and everything, i hosed the whole motor off, and pluged the 02 sensor in, and it doesnt run, it starts up and runs for a second and when i try to give it gas itll die, what do you think the problem is? i cleaned up the first 3 plugs with starting fluid and blew them off, and i put started fluid in the Tb and it makes it kick, i also tried it when the 02 unplugged, whats the deal?
tfalconier
CT
now what? i think shes gonna be for sale as a parts car soon, i just cant really deal with it right now.. too many projects, but its in pretty good shape so i dont know
projectSHO89
SHOless In St L
FOR SHO:
"I hosed the whole motor off"
Theres your problem. (if you drenched it in water) Thats a big sho no no.
Maybe, but I doubt it. Washing an engine is not a big deal IF you are prepared to address any possible consequences. Remember, this engine was designed and built to withstand wet environments. That being said, I would pull the CCRM/IRCM module, take it inside and put it on a heat register overnight. It may no longer be waterproof and may have allowed water to infiltrate causing a failure.
Insufficient information provided to try to give diagnostice help.
Best thing to do is to see if there are any codes store. Inspect the connectors for the MAF, ISC, and everything else to see if any are unplugged.
Steve
tfalconier
CT
i washed it a while ago, i cleaned out the plugs/ wells, it used to start right up, idk what happened
tfalconier
CT
like 450 obo, its got mint black leather, body is good, needs paint, need clutch, axels are out, but its all there, good parts car, or project, i wish i had more time for this car but i dont
MyFirstSHO
Guest
CT
Hey where in CT is the car? If you got slicers on it ill definetly buy them, along wit some other stuff. let me know.
tfalconier
CT
no slicers, its in ridgefield ct, its got lots of good parts, i need it gone asap, i hope som1 can make a good home for it, as i said it did run before i hosed it off so i dont know what it could be, i just dont have the time to find out
