CamelSHO
ok. i've got a 95 MTX with 70,000 miles. The car bogs down at WOT, but if i ease into the throttle the car runs fine. When i drive up hills the CE light will come on but then go back about 15 seconds later. I have to let the car warm up in the moring because if i dont the car will just bog down no matter how much gas i give it. I ran the codes in it and came up with this:
111 - System Pass (KOEO)
189 - Adaptive Fuel Rich Limit is Reached (KOEO)
I also ran the KOER Test but I didnt get any codes. The 189 code i think means the left bank is running rich? correct me if im worng. Would this cause the car to bog down like it does? Is it possible that i have a clogged cat? I did just recently install a SHOshop CAI. That wouldnt have nething to do with the problem would it?
