sho time
Toul
Columbia, SC
Shes BASICALLY all back together, got the headlight header panel from rockauto yesterday and put it in today. All thats left is two headlights, a corner, and hood pins. James you said you had some lights layin around right?
Anyone happen to have either a single clear corner, or their original amber corners?
Doing hood pins since I cant get the latch to line up no matter how much I try. Anyone have recommendations on hood pins? Is autozone runothemill stuff acceptable? And where do you install them? I know some people just replace the hood bump stop things with them right? If done that way what keeps it tight?
-DVP-
NaNaaNaNAAAA!!!
0 .· ` ' / ·. Full Retard
On the 92 I had the same problem after I pulled the support out. I think replacing the bumps is probably the best way. I might have some clips but Ill have to look when I go back home.
