stangracr67
Well, I give up. Tried to drop this into my datsun 260Z and after all the effort the engine is just too tall. So here is what I got:
Complete take out engine with 46K out of an 89, has new valve cover gaskets and intake gaskets. I have the wiring harness and 2 pcm and a LMPand a new accel coilpack. As for the RWD parts, I have a 2006 Mustang 5 speed transmission. I made my own adaptor plate out of 1/4" steel. I bought an aluminum flywheel for a 4.6 cobra engine. Its a 8 bolt just like the sho but has a larger center hole and the bolt pattern is about 1/8 inch wider. Had a peice of aluminum turned down to reduce the center hole an marked the location of the holes and had them plug welded and the reducer welded in. Then using a pipe to center the sho flywheel over the cobra flywheel I used the sho flywheel as a guide to redrill the cobra flywheel. then took it to the local speedshop to have it balanced. I think it should work, but never got to test it. also have a 4.6 starter that should work with the setup.
Here's some pics of what I got:
http://s1242.beta.photobucket.com/user/stangracr67/library/SHO%20RWD
Looking to get $1000 for everything but I'm open to offers. Will also seperate. Let me know if you have any questions.
