Sho problems, why???????????????
ira house
shreveport, La
my problems seem to come one after the other. First it was two motor mounts. Then it was locked up front caliper. Then came the clutch, and then the power steering pump. Next was the left CV joint, then immediately after that a spun rod bearing. Do the problems ever stop?????
<small>[ August 05, 2002, 02:14 AM: Message edited by: ira house ]</small>
snowwind1990
springtown, tx
If you are the original owner and your SHO has over 200K then you are where you should be. I can only say that listening to your SHO can prevent these things occuring all at once...it took some time for them to reach the totally dead state they are in....
After 200K, it is what-patty-shot-at as to how well you did the maintenance before that point...get what I mean...
If you inherited someone else's problems, then you get their nightmare.
We will help you raise your SHOchild in any way possible, parenting is never easy and the rewards are very personal.
>>>>>Ma Ma M>>>>>........ burn_out YYYYY my name? burn_out Snowwind @313,600 miles is a clue.
Some of those conditions can probably be attributed to previous owner abuse and neglect. Let the buyer beware.
billh
Moxee, WA, USA
I feel your pain. When I started having trouble with my car, it seemed that it was just one thing after another. Finally, I got the problems pretty much solved.
It could be worse.
A little girl is walking down the sidewalk, a guy pulls up next to her and rolls down his window, says "Hey little girl, if you get in the car, I'll give you a lollypop" The girl ignores him and keeps walking. He pulls up and says "Hey little girl, if you get in the car, I'll give you TWO lollypops!" The girl still ignores him, he pulls up and says "Hey little girl, if you get in the car, I'll give you the whole bag of lollypops!" The girl stops, turns toward the car, puts her hands on her hips and says "Listen Dad, you bought that damn Toyota, YOU can just ride in it!" burn_out
jthomas68
Area 51
I very rarely have had any problems with my 91 in the last 4 years since i`ve owned it.I got it from the original owner,and i too think that how it was previously used plays a key role.
David Carpenter
