Ok here's my problem, my car stalls while at driving speeds (sometimes at highway or even taking off from a stoplight). It only stalls for a second and then runs fine, the check engine light flickers each time this happens. I've tried pulling the codes using the two different procedures (3 times for each one at various times after a stalling occurance) below without seeing any codes that were relevant to my problem.
http://www.shotimes.com/php-bin/modules.php?op=modload&name=News&file=article&sid=83
http://www.midwestsho.com/instructions.html
I thought I might be doing something wrong so I took it to Autozone today and had them check and they couldn't get any bad codes either? Anyone have any problems with your processor not storing the codes? I put a new D4U1 in this summer.
I already have replaced the crankshaft sensor along with the water pump this summer. I was wondering if there's a good test to check if the cam sensor is working properly. I asked how much a cam sensor was a Autozone and they said it's not required on 3.2L DOHC shos, I didn't want to argue but thought that was funny.
I'm running out of ideas and don't want to have to take it to a mechanic if I don't have to.
Thanks!
Chad
Thanks!
Chad
