Separate the fuel pressure problem from everything else. The relay for the fuel pumps should put +12 volts, relative to the negative terminal on your battery, to the fuel pump cut-off switch in the trunk. Make sure you are using your negative battery post for one side of your VOM or test light.
This will verify that all of the ground paths back to the battery are good. Work your way (with the positive lead of your VOM) from + battery post (record your voltage, should be 12.75 or higher) then to the output of the fuel pump relay at the CCRM at the radiator with the ignition switch turned to "ON" the fuel pump should run for about 1 second, record that voltage, will be quite a bit lower lower than the first reading because there is now another path to ground through the fuel pump). Then read it at the fuel pump cut-out switch in the trunk, shouldn't be too much lower than the second reading.
Tom
You need more than a gallon of gas in the tank.
When you painted the engine, did you remove the paint in the valley of the block where the ground wire attaches?
We just went through this with 4DR4SHO's new fuel pump and strainer screen. Even with 15 gallons of gas, the new pump would not pump gas, just run. Turns out that the new screen was not allowing gas to get to the pump. So we pressurized the gas tank with an air hose to maybe 3-5 psi. This forced the fuel through the screen to the pump's rotor. The tone of the pump immediately changed and she fired right up.
Tom
Though I am interested in how you actually pressurized the tank, did you just go through the gas cap?
while it is important to have the ground path to the DIS and to have the DIS heat sink paste applied to keep it from being fried, you already have spark if you can make it run with starting fluid
Got a question. I have read die electric recommended by some. I always correct them and say heat conducting paste. Usually I have get it at a electronic shop like " Radio Shack". That is what I use on TFI on the Mustang and the Dis on SHO motor. Now am I correct? Maurice
Firing order.
Chilton's manual, should not have followed that.
She started! Did not stop though, I think my ignition wiring needs some help...
Other than that, thanks for all the help! I can't beleive it was as simple as swapping wires.
