brian gorkowski
My 1995 ATX has been getting bad gas milege of late and it bogs down in second gear with the pedel pressed about half way. After ever shift from 1 to 2 or 2 to 3 or 3 to 4 the car has no power unless you pin the pedel then the car is fast????Could it be spark plugs?TPS?Cats?
also there is a smellin the car of burnt oil probably the rear seal and some times gasoline
SHO has 140K onit.
SHO has 140K onit.
