jkichline
I had an incident with a jack a$$ yesterday (the guy refused to just leave me a lone for something that he did wrong) and I notice that everytime I stepped on the gas hard, I could see smoke through the guys headlights. I got this car from my cousin and he said that it has always used oil so I should keep my eye on it (I would have anyway). It seems that it needs a quart every 1000 miles or so. Do you know the most common thing that causes this is? Does this car have a PCV Valve? I was thinking valve seals or rings or something. I'm hoping that this doesn't get to be too bad before spring.
This may be a totally seperate issue but...
Sometimes its hard to start. Usually its when the engine is warm but it has happened when the engine is cold. I replaced the TPS and made sure my MAF sensor is clean. It seems to start easier if I give it full throttle. I tried to just give it a little throttle to see if that would make it start easier but it didn't seem to help. Crank and cam position sensors were replaced when I did the upper and lower 60K's last spring.
