HAPPY TIMES !!!!!!!!!!!
Changed crank position sensor... no need to describe the horrors and agony we must suffer to change this sensor....
Car fired right away, Thank you Lord !!!!
all gauges work. it says it has low oil.. yet is full of oil. and oil pressure is good per both the probes and sho sensors... must investigate this.
I got the usual codes related to the fuel pump since i have no CCRM.
codes: 543 and 556, fuel pump circuit failure... (i did not wire the high speed circuit for pump, no need.)
so now to fill it with water, get a new air filter since the stock airbox is in no way going to work (no room in this smaller engine bay.), i been told K & N will **** the maf so i will get something with a dry filtering media. (apexi maybe).
power steering will be sorted out soon (electric pump conversion from a mini cooper).
Will post pics and maybe a vid as soon as its decent looking and making some vroom vroom noises.
