SHO ford probe project
jonheese
Used-To-Know-It-All
Fogelsville, PA
Okay, I see what you mean now...
I'm 99.9% sure that the mounting boss on the right (rear) side is just a solid chunk of aluminum that can be safely removed.
I would imagine that the left one is also solid aluminum with nothing important running through it, but I'm not really sure.
Has anyone else experimented with a 3.0L head in this respect?
probe_racer
california
cut the piece off, its just a chunk of aluminium. now i have no clearance problems for my slave cylinder for the clutch.
test fitting transmission now
EDIT
transmission bolted perfectly with slave master cylinder now that the chunk of metal has been cut off.
engine and transmission do fit in the engine bay... the issue now is that there is about 1/4 of an inch or less of clearance between the passengers side engine bay and the sho engine.
I will take some pics on sunday to show you guys.
thanks for your feedback so far.
llamaking122
Green Machine
Columbus, Ohio
EDIT
so its going to be easier to work on than a regular SHO? hahahahhhahahahhahahahhah i had to
us
ford probe parts
-- dude try searching for different sites that will give you discounts on ford probe parts. you can get great bargains on similar quality. also try to expand your search on some parts that might improve your cars performance. goodluck.
probe_racer
california
sooooo another big thing that had to be done to make sure everything fit safely (mainly fit), I had to move the whole assembly, both engine and tranny 1/2" or so towards the drivers side to give clearance to the crankshaft pulley and the other accessories, otherwise they would rub against the passenger side fender/frame.
this engine is not going in without a fight so far.
im hoping i dont have to move it even more because that would definetively is going to need custom halfshafts...
us
ford probe parts
probe_racer
california
engine and tranny are in position and seems that the hood closes with no problem, the next big thing in adapting this to my car is a Y pipe...
any recommendations or suggestions ???
fa SHO
lakewood, co
no shit eh? wish i would have seen this thread sooner. ive had my vulcan tranny and sho motor bolted up for a little while and just recently got around to fitting it in
instead of messing with the mounts or half shafts on my mx6. i kicked the frame back a bit on the passenger side to clear all the pulleys. but there is absolutely no room for the power steering. i take it that your power steering clears fine the way you have it mounted up?? how did you move the whole assembly over a half inch, slot the mounts??
DrivingEnthusiast
Texas
We need some pics here! Extensive!
For those of us who'd like to do a nice MX-6 or Probe with the engine it should have come with in the first place!
zach
Auburn, WA
This and that. I'm going to embarking on this swap in lieu of my FE3 swap very soon.
fa SHO
lakewood, co
funny i ditched my fe3 for the same reason.....i have some pics if you want em zach. hit me up here or on mx6.com if you need anything
zach
Auburn, WA
Oh jesus Z...hahaha
Didn't realize this was you :)
You ever measure the 3.4 V8 in size?
I found some interesting materials with transmission fitments.
fa SHO
lakewood, co
ive never even considered it. i want to keep the torque as low as possible as these vulcan h type gearboxes arent easy to come across. if you do check into it let me know how that works out. id definitely lmao with a v8 under the hood of a 1g mx6 :)
supercharged3.0
Los Angeles
Manuel!! You know the rules.... where are the pictures???
Basically, you want to show up on a FFF show with your new setup, is that correct? Do you need any help?
probe_racer
california
so now im ordering parts that are needed to make fitment better, issue is the oil filter will not clear my radiator so im thinking of relocating the oil filter since im not sure about the parts what do you SHO masters think??
Oil Filter Bypass Ford & Chrysler .188 in. Thread, 3.125 in. x 3.375 in. O-Ring, Kit
http://www.summitracing.com/parts/MRG-7692/
and then i could use
Fitting, Straight, -10 AN Male to 3/4 in. NPT Male, Aluminum, Blue Anodized
to convert the connections to 10AN which then will be easy enough to connect with SSlines to a remote dual filter or single filter adapter.
Any thoughts on this?? suggestions???
Also the pressure plate will be a sachs (is that a good brand??) and will be mated to a probe clutchmasters clutch disk. which should be able to hold the extra HP since southbech will not sell me the clutch disk by itself.
thanks for any input..
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
Get ahold of SHOSource for the disc. They can get what you want made. I've talked with them before about having a custom clutch made for my V8 MTX.
- James
probe_racer
california
ok here is a late late update on this project, but i need your help again guys
engine and wiring are from a 92 sho mtx
engine and wiring is all done but i have run into and issue..
the DIS has a wire that is supposed to go the clutch switch, this is pin 6 on the DIS and gets power whenever the clutch switch is closed.
what is the voltage going through that???
does the SHO taurus has two switches on the clutch pedal?? or is that the same switch used for the engine control computer???
I'm at a lost on this. since my car only has one clutch switch.
also i have been removing extra connectors from the engine harness that i will not use for the probe. what is the little square connector next to the air temp connector for? it is for anything engine related or can i delete that one too.
Off Road SHO
Moderator
When you turn the ignition switch to the "START" position, the ignition switch sends 12 volts to the clutch pedal switch. The clutch switch is open at all times except when you push in the clutch.
When you do that, the pedal switch closes and sends that 12 volts to two places. One place is to the starter solenoid, which is a switch itself. The other place is position 6 of the DIS. The one and only clutch pedal switch on the SHO only does those two things and nothing else. The wire from the ignition switch to the clutch switch is white w/ a pink stripe. The wire from the clutch switch to the two other locations (starter solenoid and DIS module) is red w/ light blue stripe.
Do not confuse this red w/ light blue wire that goes to pin 6 of the DIS and is ONLY hot while the Ignition key is in the START position, with the red w/ light green wire that attaches to pin 1 of the DIS. That red w/ light green wire is also fed by the Ignition Switch BUT, is hot in both the START AND RUN position.
That red w/ light green wire not only feeds switched, 12 volt power to the DIS, but also to the Crankshaft Position Sensor, the Camshaft Position Sensor, the Coil Pack and the Condenser on the side of the coil pack (the condenser keeps the ignition system from generating electrical noise that the radios pick up).
Hope that helps.
Tom
ribeye2065
