Rockledge
Pluggin' away
OK, here's the scoop.
I'm driving along and all of the sudden the SHO cuts out, seemingly at the same time that I went over a small bump. It almost seemed to me like it had popped out of gear, that's how quick it died. I was able to restart it and it ran fine for another mile or so, and then same thing. Now it won't start at all. Tried cranking it many times thinking it might have been related to a CMP sensor problem, but no start.
It was dark, but I was still able to pull codes codes, here's what I get:
543 - Fuel pump monitor circuit shows no power
524 - Problem in low speed fuel pump circuit
Of course I'm thinking bad relay and/or fuel pump now but I tried pushing in the fuel pressure relief valve and it seemed to be spraying out plenty of fuel, which would seem to indicate it's getting fuel, no? shrug
On a related note, I had gotten a 542 (Fuel pump open, bad ground or always on) code a few months ago but it went away when I replaced my 02 sensors. And yes the pump was noisy.
Thanks in advance for any feedback.
