Ford DIS/EDIS "Waste-Spark" Ignition Systems
Every time I read this article, I learn something new (or something I glossed over the first time around) !
New (to me) is the fact that when sending a fire-signal to a given cylinder in the SHO, the PCM (EEC) will scan both cylinders in a pair, and send the signal to the cylinder with the most electrical resistance (caused by high compression pressures, I.e. on the compression stroke). Thus, getting us back to my original question: "What would happen if secondary wires were switched between cylinders in a pair ?
It would seem, given the above, that even if the wires were switched, the computer would still send the signal to the correct cylinder.
Another question arises from the statement in the article "Half the spark plugs actually see a different polarity than the others do."
I would think that this would only be the case when a cylinder was the trailing cylinder in the pair, completing the circuit back to the DIS system, and that the computer would only send positive (polarity) signals out. And that each cylinder would sequentially be the "firing" cylinder, and later in the firing order, the trailing or exhausting cylinder, carrying a negative signal back to the computer.
Right, or Wrong ?
Again, thanks to Rockledge for starying all this with the DIS/EDIS article !
Dino
