My SHO died on the highway yesterday. It had no power and it continually got worst as I tried to push it home. It would rev up to well over 4 rpms without moving.
It has never really had much power since I got it a month ago but I was about to do a 60k to replace that.
My idle normally sits at about 1.2k so I was going to reset the idle today.
I ran a code test and came up with 13 and 19. I think 19 is for a solenoid problem because the engine turns over if I am on the clutch while turning the key (without turning on the engine-just at one point when turning the key).
I am not sure what 13 is.
When the car died I could see smoke coming from the area by the timing belt. This always smokes when I raise the RPMS over 4k.
I could also smell the clutch burning when I tried to rev too much. I can shift Ok between all gears so I not sure if there is a clutch problem or it was just burning because I was revving and the car wasn't moving?
Question then: what could be the problem? timing belt? clutch? sensor? computer? or just dead?
Than you.
Than you.
