SHO and Flex convert to vent to atmosphere with factory blow off valves
EcoPowerParts
AZ
I just converted my factory BoV to FTA on my Flex today.
What does this do for you?
Nothing but making a PFFFFT noise when you lift the throttle under boost.
Is there any downsides to this?
No, the car is speed desnsity so releasing the air from the turbos to atmosphere when the blow off valves open does not negatively impact the tune, factory or modified. There is no MAF in the ecoboost motors, only dual MAP.
BTW, I couldn't find 1" vacuum "*******" to block off the factory tubing so I went to Home Depot and searched around, found some 1" rubber chair leg "tips" to use, worked pretty good so far.
Front Blow off Valve and blocked off tube
2013 05 08112815
Another shot of the factory Blow off Valve with the return tube removed - vent to atmosphere
2013 05 08112820
Close up of rear portion of intake tubing with blow off valve return hose removed and blocked off. For me easiest way to get to this area and remove tubing was to remove the intake tubing and rotate to access the clamp that held the tubing onto the blow off valve.
2013 05 08112843
Rear Blow off Valve
2013 05 08112918
Complete turbo to intercooler pipe with Blow off Valves circled
2013 05 08113132
Racer X
SHO Pilot, Retired
Connecticut
Correct me if I'm wrong, but if the charge that's being vented is after the MAF, isn't that going to throw off the metering, in so much that the engine has less air mass available than the ECU thinks it does?
bpd1151
Lurking Around
SHOcago 'Burbs
Interesting stuff. You've been coming up with a lot unique ideas as of late.
Kudos.
Boggus
2013 SHO PP
Texas
Will try that tomorrow. I vented my pcv to the atmosphere also, rubber ******* the lines on the intake.
EcoBrick Bob
Clear Lake, IA Naples, Fl
Where was the PCV vented to previously?
Some of us eliminated the oil blow by line from front valve cover into the front turbo air inlet. Couldn't believe how much oil has collected in the little filter added to the valve cover. All that oil was going into the turbos, intercooler, and eventually the engine. Back side has a catch-can device, so why not the front?
EcoPowerParts
AZ
I'm going to do a catch can on the front PCV valve this week too. :)
jdeprato
Fredericksburg, VA
Since there is no pressure build up on your recirculation side hole plug it should be good as long as it can hold up the temperature of the engine bay. Thanks for the virtually free mod. Can't wait to see the piping PPE comes up with.
Boggus
2013 SHO PP
Texas
Just completed mine. Found some 1" vinyl caps at ACE that did the trick.
jdeprato
Fredericksburg, VA
I was able to test this out tonight and its pretty loud when you run WOT manually shifting. I can't imagine it being much louder. The real concern as you mentioned is actually how much boost can they actually hold.
Boggus
2013 SHO PP
Texas
I did mine with the mini cone filters from autozone. Now I get a wiff of oil smell every now and then when driving since I vented the PCV to the atmosphere.
shomeda$
Alabama
Interested... Keep me informed bro. Also, let me know how the boost pipe comes out.. I might wanna pic one of those up from Paul as well....
EcoBrick Bob
Excuse me for hyjacking this thread... but in the interest of NEW ideas... I have bolted 4 castors to my roof and 2 to each to the front hood and rear trunk.... JUST IN CASE I END UP UPSIDE DOWN! This is my effort to stay ahead of BPD....
markmoomnu
