Sho acromyns
RAYJAY
WHO ME ?
UNION DALE PA
CAI - Cold Air Intake kit
IAC - Intake Air Control, solenoid valve and its surge reservoir
IAB/IAC Valve - Idle Air Bypass/Control Valve
ACT sensor - Air Charge Temperature Sensor
CID - CMP - Camshaft Position Sensor circuit or signal
CPS CAS - Crank Shaft Position Sensor, Crank Angle Sensor, CKP REF - Crankshaft Reference
DIS - Direct Ignition System, Electronic Distributorless Ignition System (EDIS)
TPS - Throttle Position Sensor
MAF - Mass Air Flow Sensor
HO2S - Heated Oxygen Sensor
ECT - Engine Coolant Temp Sensor
BAP - barometric absolute pressure sensor
MAP - Manifold Absolute Pressure Sensor
ECM - Electronic Control Module
EATC - Electronic Auto Temp Control, hold down the Floor and Automatic buttons until it reads a code...no failure(888) result.
WOT - Wide Open Throttle
TOB - Throw Out Bearing
ASB - Aluminum Subframe Bushings.
UPM - Upper preventine maint 60K
LPM - Lifetime Performance Module OR Lower preventine maint
PP - Pressure Plate
STB's - ?
BBB's - Big Bore Butterflies
LSD's - ?
BBB - big bore butterflies
EH - extrude hone
DIS - Distributorless Ignition System
ACT - Aircharge Temperature Sensor
TB - Throttle body
ECT - Engine Coolant Temperature sensor
UDP - Under Drive Pulley(s)
vRef - Voltage Reference
CPS - Crankshaft Position Sensor
CID - Cylinder ID sensor (cam sensor)
ECP/EEC - Electronic Control Processor....the brain...computer
IRCM/ICM - Integrated Relay Control Module
OEM - Original Equipment Manufacturer
SHO - **** Happens Often
hawkeye18
Sorta cares
Norfolk, VA
STBs = Strut Tower Braces
LSD = Limited Slip Differential (Quaife is who manufactures the only LSD available for the SHO)
