boat
Likes blue ones
I am wondering about something...
How often do shims actually wear out on the 3.2L? I have limited resources and I can get spark plugs and the valve cover gaskets w/plug well seals, but can't really afford the shim kit rental. I realize the shims are there to protect the cams from wearing out.
The motor has had the piston rings changed and the rod bearings about 40k ago, not sure if that has any bearing on the shims wearing or not???
Is it okay to do the seals, gaskets, and plugs, then do the plug wires and intake stuff later? I realize I may not get the best benefit right off the bat, but it would take care of my oil leakage and this funny gurgling noise I get when I start the car, sometimes. I have been informed this "gurgling" is from my plug wells having oil in them.
Money is just tight right now...Thanks
