Shim question for You SHO V8 & V6 guys
Bruce M
SHOBAM
Kingston, MA
I have a bunch of shims out of a 1997 SHO V8; they are exactly the same diameter as the ones out of the Yamaha V6s.The thickness follows the same increments. However, these shims have a machined hole bored through the shim, off center near the edge. It doesn’t look like it would come anywhere near the cam lobe. The hole might be 2mm in dia. Question, Is that hole to help oil through or to help remove it? Has anyone used these in a V6? I'm not a SHO V8 guy.
Thanks
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
They are to allow you to remove them. For the V8 you shoot compressed air in there to get them out. I would not use them in a V6.
Bruce M
SHOBAM
Kingston, MA
Thanks Loudsho92
I have 32 caps and shims 2625 - 2675, That I pulled from a wreck. Given that I have all V6s. I'll throw them on Ebay
thanks Again
Bruce M
Mr Anonymous
Tire Wall
We use them in V6 cars all the time, they're fine. In fact they are better than fine as they are a little harder than the V6 shims so they don't tend to wear as much.
When the V8 shims were still available, that's what Josh was selling for new shims for the V6 cars.
Bruce M
SHOBAM
Kingston, MA
Thanks Mr. Anonymous!
I didn't thinnk that there was a problem with them being used in a V6, one guy on this thread advised against it. In fact; i have a 1990 that Im working on right now, it will get the v8 shims.
shobam
cetroutt
troll
SEMO
so V8 shims are okay to use in the V6? and i know it's an old thread i was just wondering about this and found that it had been asked and i need lots of reassurance.
Off Road SHO
Moderator
V6 SHO, V8 SHO, or Yamaha dealer for 29mm valve shims.
And be very careful when buying used shims. There is another common size for motorcycles that is 29.5mm in diameter that do not fit our buckets. Most sellers on FleaBay can't read a caliper, let alone know what a millimeter is, so be wary. BTW, would anybody like to buy some 29.5 mm shims? :rofl:
Tom
AREA 91
PA SHO SHOP
Area 91
Tom
I have a grinding wheel.....:naughty:
Storm-Chaser
Shit Louis
Aw, what'sa half-millermeter - cain't see it anyway. Just hammer 'em in there - they'll fit. Where's your 'git-r-dun' attitude at :thumb:
cetroutt - if you know which sizes you need, James (St Louis SHO) probably has a decent collection of shims and probably every size you need.
cetroutt
troll
SEMO
well i haven't checked it yet. to be truthful i'm kinda intimidated by the thought of doing it. i know i need to do it and i really want to do it so i can i can better care for my SHO. it's just going to take me a few weeks of reserch and reading and rereading all of the info available. honestly i really don't know what i would do if it weren't for all of you guys and this site. thanks to everyone.
