shifter
bigsho
sterling va usa
When I shift it squeaks. Its the shifter or around that area. Can I **** this, if so what should I use. Any other things it could be. Thanks
Robbie
95 MTX red
SS SNORKEL
26 sway bar on
24 sway bar on floor
SHO NUT motor mounts on floor
IPT 3 gauge pod in box on floor
There are a couple of locations in the shifter box under the stalk that can be lubricated, but they are not trivial to access. You really need to identify the location of the noise before you can correct it.
Scott
