shifter/exhaust clearance
woody32
central, PA
hey guys,anyone know if a walker turbo tube (made by walker under the dynomax name) will work with a rod shifted car ?
the piece i have acess to is a walker part #(yellow label)8638744379
501958 stamped in the metal of the piece.
my car is a 91 mtx sho(rod shifted),but this pipe (listed above) is supposed to be for a cable shifted car.anyone know ?
masho95
got Zex?
Chicopee, MA
If the pipe if for a cable shifted car, it's most likely not going to fit a rod shifter car. You need a bent pipe to go around the rod shifter. You should contact the seller for more info about the pipe.
