shift solenoid?
flynsho
chicago
where is the shift solenoid located? is it on the outside of the trans or inside?
'94SHO
Towley rules!!
R.I.
They are inside the tranny, you will see electrical connections going to them
if you pull your trans. filter. Try a search of " ATX diagrams" Or search "ATX"
and if it's not an ATX, you don't have a shift solenoid(s)..:naughty:
projectSHO89
SHOless In St L
...you will see electrical connections going to them
No, you won't. The shift solenoids are under the SIDE cover. The connector is on the TOP of the tranny.
Steve
