93MTXSHO_STUD
My car's shifting is getting worse here are some symptoms. When I put the clutch in it makes the whinning noise from the TOB. Now for the shifting.... sometimes well almost all the times it has hard times shifting through the gears like it seems like your going through a puzzle to find each gear and not to mention sometimes but rarely it grinds a little bit. When your in gear you can move the shifter all around and it feels like your in neutral. aka u have like aboout 1.5 inches from side the left side and 1.5 from the right of play. Now recently when Im trying to shift at high RPM's like 5000+ it doesnt want to shift and it you have to left it rev down before it will go into gear. I'm thinking it might be the clutch but have never done one of this car. What about the play in the shifter? Can you adjust the "black box" shifter box or do you have to get a whole new assembly?
