SFC question
RJ-92
Crappy NYS
I making some SFCs and I don't have access to the car to take measurements. Any one have Shorty SFCs know how long they are, or what gauge steel is used. Thanx in advance.
Ron Wazz
Red 92 MTX 109K
ss y-pipe,
dynomax cat-back w/1 superturbo & 1 ultra-flo muffler,
street/strip clutch,
18Lb. fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
Konis and Eibachs, 26mm RSB
In storage for the winter
shotyme95
Cleveland, NY USA
Check out shotimes. There is a link for them.
95 MTX Salvage Title; Saved from crusher!
K&N w/Ram Air,
Toyo Tires,
Fishtanks
Fog lamp mod
Dynomax exhaust
SFC's
190 lph fuel pump
1slickRED89
Guest
Toledo Ohio
the distance from the rear weld point to the closest point on the 'frame' is 46"-47" i had a set installed and have since removed them in favor of long ones
the long ones seem much better suited for chassis stiffing. they are made of 1" square tube with a 1/8 wall thickness, about 72" long. then bent with a shallow bend 46" from one side.
good luck
Corey
89SHO
1slickRED89
Guest
Toledo Ohio
deconblue said: "BTW that's 1" x 2" steel tubing."
really...i was talking about two 1"x1" sqaure tubes partailly (50% of total length) welded down the center to make a 1"x2" bar (weld them after the bending!!). that makes a bar with four vertical walls vs. everone elses two-wall design. i would almost recomend square tube slightly larger than 1" because the 'frame rail' is just a shave wider that 2" and they can be tough to weld on one side, sometimes, due to the shape of the bottom of the framerail.
this is defintly a case of spend time makeing it, or spend money buying it. to each, his own.
Corey
89SHO
DeaconBlue
Cleveland, Ohio
Yes that maybe stronger, but it will weigh more. We didn't have any problems welding them to the uni-body channels, but then as you said to each his own.
CTOESHO
DeKalb, IL, USA
Toolman,
How much do your long SFC's weigh? Whats the price difference of the shorties? Thanks.
Mike
93mtx
