Caliper application ?
RJ-92
Crappy NYS
I heard that you can use the cobra calipers with the 11.6 rotors with a little bracket modification. What kind of modification?
Aren't corvette calipers the same as the cobra ones? If so what year vette. Many more were produced and it would definately be cheaper to get vette ones.
Ron Wazz
Red 92 MTX 109K
ss y-pipe,
dynomax cat-back w/1 superturbo & 1 ultra-flo muffler,
street/strip clutch,
18Lb. fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
Konis and Eibachs, 26mm RSB
In storage for the winter
S
SHOFF
Guest
I have cobra calipers and rotors sitting at home wanted to take a ride on my sho Please let me know what i have to do to put them on
Sho shop cams
80mm mass air
big bore butterflys
underdrive pullys
strut bars, front and rear
cold air intake
high flow y pipe and cads
18 inch quatem tek wheels
eibach springs
2 tvs
dvd
playstation
5000 watt system
www.shoracing.com/pix/g2/donnyc_93sho.jpg
RStalveyARFF
too many shos
Georgetown, MA
from what I heard, it involves putting the left caliper on the right side and vice versa. This would only work for the 96 upgrade. You are correct, they are both PBR calipers, but I'm not sure if they bolt up the same.
DeaconBlue
Cleveland, Ohio
The PBR calipers, mounting brackets and 13" rotors (once redrilled for the 5 x 4.25" lug pattern) bolt up to the '94-95 spindles with no modifications. Yes you have to swap sides with the calipers because they are mounted on the back side on a Cobra vs. the front side on a Taurus (bled screw must be at the top of the caliper).
The PBR mounting brackets can also be modified (welding on material, grinding, drill and tapping required) to work with the 11.6" x 1.10" wide rotors and fit inside 16" rims.
These are the HD PBR units found on the Cobra and C4 Corvette with 13" front brakes and 1.10" wide rotors. You can NOT use the std duty PBR calipers found on the C4 Corvette with 12" front brakes and 0.82" wide rotors.
95 MTX
with a few mods
