SHOpoor
For sale is my 1993 MTX - Red with Mocha interior.
This car began being built a few years ago as part of a family hobby. My son got there first and by working with him, I got the bug myself.
This car was built to be a fun weekend ride that I can use on the street or for a few track days and it has not disappointed me. It has performed flawlessly on the street and at the track. It has visited Watkins Glen, Summit Point, Thunderbolt and Pocono and has earned the respect from many M3 and porche drivers in the BMW club that I run with.
As you review the list of modifications you will see that I have invested quite a bit of money. As with most car hobbies, it's not possible to get back what you have invested. That's the price you pay for the enjoyment that building and driving the car brings you. You can't duplicate this car for twice the asking price.
In addition, I have a storage building full of spare parts that we can discuss. I will include a spare transmission (rebuilt but no quaife - the quaife is in the car), heads, intake, dashboard, and a console. There is plenty more to discuss, including a matching ATX parts car that my wife used to drive.
Asking $5000
Engine:
3.2 Short Block (’93 - 3.0 Block, bored with stock 3.2 pistons/rods & crank)
Complete engine rebuild (rings, bearings, seals, etc)
3.0 Heads & Cams – Gasket Match/Ported & Polished
3.2 Oil Pump
Intake – Gasket Match/Ported & Polished – Powder coated
Valve Covers – Powder coated
3.2 Injectors (WitchHunter Cleaned & Flow tested))
ShoNut Reinforced Motor Mounts
ShoNut Clutch
Big-Bore Butterflies (SHOBros)
Walpro 155 lph fuel pump
A/C - new compressor & seals/o’rings
Dual Core Radiator
Exhaust:
Magnaflow Y-Pipe
Dynomax Resonator Pipe
Transmission:
Drain Plug
Quaife Torque Biasing Differential
Full Rebuild - All bearings, Seals & refurbished blocking rings
Suspension:
ShoNut Aluminum Sub Frame Bushings
Intrax Springs
Koni Struts
TPR Bushings at all points
22mm Front Sway Bar
26mm Rear Sway Bar
HD TPR Rear Sway Bar Links
H-Brace – Aluminum (Bruce-Custom)
Full Length Sub-Frame Connectors
Ingalls adjustable rear control arms
Brakes:
Front - Baer 12.5” Upgrade
Street - Baer drilled & slotted 1 piece rotors
Track - TCE 2-piece slotted rotors
SS Brake Lines
Rear - Gen 1 with vented Rotors
SS Brake Lines
Brake Bias Plugs
Wheels / Tires:
Street:
Wheels = ASE - ASA JS5 - 16 x 7.5
Tires = Yokohama AVS ES100
245/45 ZR16
Track:
Wheels = Team Dynamics 1.2 17 x 8 Silver
Tires = BF Goodrich G-Force R1
225/45/ZR17
Electrical:
Battery relocated to trunk (Optima Yellow top)
LED Day-Lights in Fishtanks
Interior:
Switch Panel in DIN Pocket
VAPS cut off
Day-Lights cut off
Gauges- Auto-Meter
Ultra-Lite Oil Pressure & Volt Meter
Fuel Pump Access Door
Street: 50/50 Cloth seat set
Track: Corbeau Fixed Back Seats
Driver - FX1
Passenger - Forza II
Simpson 6 Point Cam Lock Harnesses
4-Point Roll Bar (SHO Source)
Please use this link to review the build history and current pictures. The most recent pictures are on the last few pages.
http://www.cardomain.com/ride/1607975
I am posting this car here so that the SHO community has the first opportunity to own this car. If it doesn't sell in a few weeks, I will post it on Ebay.
Please contact me with any questions.
Thanks
SHOpoor
Asking $5000
Engine:
3.2 Oil Pump
ShoNut Clutch
Dual Core Radiator
Exhaust:
Magnaflow Y-Pipe
Transmission:
Drain Plug
Suspension:
Intrax Springs
Koni Struts
22mm Front Sway Bar
26mm Rear Sway Bar
Brakes:
SS Brake Lines
SS Brake Lines
Brake Bias Plugs
Wheels / Tires:
Street:
245/45 ZR16
Track:
225/45/ZR17
Electrical:
Interior:
VAPS cut off
Day-Lights cut off
Gauges- Auto-Meter
Driver - FX1
Thanks
SHOpoor
