To clear-up the confusion . . . .
SHOZ123 is correct. There are two different subframe "kits" - the Gen I/II recall kit, and the Gen III service kit. They are different "kits", that have different parts which are not interchangeable.
Gen I/II
The Gen I/II subframe
recall kits are the result of a SAFETY recall. The kit is designed to
replace the subframe bolt nut plate, which is simply a stamped-steel "nut" that is held in place with two tabs. Corrosion causes that stamped OEM nut to split, and results in the subframe bolt pulling-through the unibody frame-rail in the floor-pan below your feet.
The kit includes a much thicker steel plate and much larger nut welded to that plate, in place of the stamped-steel nut, that prevents this failure from occuring. The nut plate is kinda similar to the Gen III nut plate shown in Paul's image above.
Neither the subframe bolt nor the nut plate are part of the frame. The there are two locking "tabs" that are small tabs stamped into the unibody frame, which hold the subframe bolt nut plate in place and prevent it from spinning.
The recall kit SHOULD be done for all Gen I/II SHOs, especially given their age. The recall was directed at the "rust-belt" states, as corrosion from winter road-salt rapidly accelerates the corrosion and failure of the nut. But over time, most of these will eventually fail in the Gen I/II SHOs given the added torque of the SHO engine.
Installing the Gen I/II recall kit will not affect being able to lower the subframe, once done.
Gen III
The Gen III subframe
service kits are designed to replace the subframe bolt nut plate,
if it has broken free inside the nut plate. Unlike the Gen I/II recall kit, this is NOT a safety recall item, but simply a service kit if the nut for the subframe bolt begins to spin inside the nut plate assembly.
recall kits are needed if the nuts for your subframe bolts break free of the frame, the dont NEED to be done to swap the subframe bushings, and doing the recall jits wont ever stop you from lowing the subframe again
