Service Engine Light
kvonmc
St. Paul, MN
My car just started to act up withing the last couple of days. It started with the "Low Coolent" light. It would light up sometimes, but when I checked the coolent level, it was full. Now just tonight my "Service Engine Soon" light came on. I noticed it is running a little rough (It always idled a little rough, which I need to figue out why and take care of as well). Any ideas on any of these problems? I will be taking it in the the shop soon, but I just wanted to know what you guys think. Thanks.
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
The code is probably either a coil code, a MAF code, or a TPS code.
The coolant thing is normal, that sensor gets fouled up sometimes. Either clean the sensor or just unplug it.
Go to AutoZone and they will read your codes.
The coolant sensor is a bit flaky, I just unplugged mine.
kvonmc
St. Paul, MN
Thanks for the replies, I've been so busy to respond. But another quick question; is it ok for me to drive it until I can get it looked at, or am I just an idiot for asking.
Ian Macoomb
Ottawa, Ontario, Canada
If it's just a little rough you won't hurt anything by driving it. If the check engine light starts flashing, then you should avoid driving it.
Sounds like a bad coil (or a few).
Craig Van Buren
Woodinville
I had the same issue with the coolant light.
Yeah I had my coolant light came on so I put some coolant in the car. A few days later the coolant light came on so I figured something was f-ed up. I checked the levels and everything is full. Then the light went off and it was fine. I think it might have to do with funky weather. I don't know, but I don't think it was a serious problem, just an inconvenience. Oh well, don't sweat it.
Craig
