MaDDaDDaM
There is a severe shudder any time I attempt to apply any power to the car. It jerks back and forward violently. I have no idea what the problem would be, but I hope it is possibly a simple engine problem and not anything to do with the transaxle. I don't think that is the case because I can put the car in gear and it will run fine. But as soon as I apply power, it seems as if the engine chokes and temporarily siezes up or something. It violently shudders and jerks forwards and back almost like it does when a person is trying to learn to drive stick for the first time. Again, I can put it into gear and gently give it some gas from about 2-3000 rpm, but if I go much higher than that, or if I press down significantly on the peddle, it starts shuddering again. Any insight into this problem would be greatly appreciated, as this is my daily driver, and being immobilized will totally screw me. :jpshakeh: Thank you! Addam.
