secondary butterflies not opening
MADMIKE
Muskogee,oklahoma
Yeah.. as the title says.. what could be the prob? i did a search..not much helped me.. I understand that when the car is off they are open and then when you start the car they close. I have nothing after 4000 rpm.. I was reading on another post it could be a computer? what computer is it? And where is the computer at.. Pics would help out great..I need this prob fixed ASAP.
Thanks,Mike :bonk:
xpnsiv93
Corrupt state, IL
it could also possibly be the vacuum became unattached???...i also believe on the backside of the intake there is a sensor and vacuum hoses that control the secondaries...i could be wrong...so dont quote me, go check those out and see, o by the way it's the small/large cansiter w/vacuum hoses connected to it and the sensor next to it...hope that helps and someone w/MORE xprience on this can help any more than my $.02
PROPHET
Well-Known Member
Tonytown, Texas.
When i reinstalled my intake i accidentally switched the two hoses that connect to the black cannister behind the intake above the rear valve cover and that caused the seconderies to stay open, i switched them at a members suggestion and they work now.
Off Road SHO
Moderator
Tony is correct, the little black cannister is a one way valve with a small filter on the inside. There are usually small colored dots, a white and a yellow next to the two hose connection points. First try reversing those two hoses.
The computer tells the little black solenoid to release the vacuum that holds the secondaries closed and the secondarys' shaft springs snap the secondaries open.
Tom
MADMIKE
Muskogee,oklahoma
just got done checking it. that little canister is getting vacuum. and the butterflys open when i take off the bottom line... so im gonna check the electrical side next
AREA 91
PA SHO SHOP
Area 91
Make sure that you don't have the wrong wire plugged in for the secondarys. It is possible that the plug for the coolant sensor is plugged in by accident! If this is the case, it will "blow up" the computer!!! Trust me, I found out the hard way. :thumb:
