Secondary Air flow injection code
phillyphan56
Pennsylvania
i got a secondary air flow injection code on my 96 sho says wrong air flow amount detected or something...what could that be?
Probably a bad relay for the SAI pump. It would help to have the exact code.
madsho97
Minneapolis, Minnesota
I've had the same thing since I bought mine. I didn't have the time to fix it, then the weather turned colder and the CEL turned off.
It doesn't affect driveability though.
phillyphan56
Pennsylvania
yeah its weird but because of the light on it was drastically effecting my gas mileage i turned it off and i got my gas mileage back it hasnt returned after 80 miles atleast yet so idk it turned on when it was cold but stayed off ill have to keep my eye on it i guess
phillyphan56
Pennsylvania
yeah i know its probably more the cat deficiency code more than the SAI code the cat deficiency will stay off for who knows how long too its fickle sometimes its right when the monitors come back sometimes its 300 miles but when the light is off i get much better mileage
jmpSHO
Massachusetts
Yeah that code will not affect gas miliage and it will most definately come back.
97SHOgt
Cincinnati, OH
My '97 has the same thing. Improper Secondary Airflow I think it was. Has no affect on anything. Just annoying.
madsho97
The check engine light was off all winter, then then last week when the temp went above 40 again the light came back on. It's the damnedest thing.
stephen newberg
Ladysmith, BC, Canada
411? Yes, I think Paul has it here. I get it all the time. The relay comes and goes depending on the temp outside, the humidity, and its particular mood for the day. I suppose I should replace it, but as I know it is pretty meaningless, I had been ignoring it for during the winter, and now it is not showing up, waiting for next fall, I suspect.
Paul, could you do one of your photos or two showing where this thing is located and the procedure list for putting a new one in? Its getting warmer out there regularly, so I might as well do it, now that I am being reminded of it.
pax, smn
If the relay is intermittent it is probably a connector problem. Otherwise it is a SS relay and is either good or isn't.
