reags8
While attempting to chase down a vacuum leak and rout the vacuum lines correctly after taking the intake off I developed a problem with the rear sec. actuator.
It is stuck closed - When I start the car both actuators are closed and when I shut it off the rear stays closed. I tried running the car up to 4,000 rpms to see if the rear would "free itself" and I can't tell you if it opened or not because the car is running like crap due to a vacuum leak. When I shut the car down it was stuck closed again. I can manually open it with the car off and it will close again at idle but not open when off.
I'm planning on taking the intake off and replacing all the vacuum lines that I can get to and the gaskets. While its off should I start looking for a replacement actuator ? Where ?
How much $$$ ?
Thanks
How much $$$ ?
Thanks
So yeah, forums: Anyplace new we can get them from? Ford part number or other cars these things were on?
