Seat Question
UnsungZero
Carol Stream, IL
is it possible to make a passenger side seat work on the drivers side with simple hardware swapping from the drivers seat...or do i have to make stuff
element913
SHO Owner Elite
SF Bay Area, CA
I believe the wiring is the same for both sides, however the drivers switch is the opposite of the passenger switch (you would want to use a driver side switch). This works fine for the bottom of the seat (you will have to cut a spot for the switch to come through). The top of the seat is another story, you will have to pull the leather covers off and put them on a driver side frame. This is simple but time consuming (expect to have bruised fingers after).
