SARC switch install question
DavidT
TN
If I splice into the sarc brain and use a lighted 3 prong switch, how would I wire the switch? Would I need an inline fuse?
DavidT
TN
is a 3 prong switch even possible in THIS setup?
Vroom
Un-Moderator
South Dakota
I only know of 3 prong switches that you use two for the power wire and one for ground wire.
It sounds backwards from what you're trying. I'm sure someone that's done the SARC mod will be able to help you out more.
shoteen95
isn't a teen :D
Dearborn Heights, MI
i thought there was an article on V8SHO about an SARC switch, can't recall if there were directions on how to hook it up or not
When switching the wire in the back at the SARC brain you are turning the sensor ground off. No power there to light a bulb.
EDIT: Check out my other post in the performance section for the answer.
