We are having a sale on new loaded Gen1 calipers: SHOBros
I thought 89 calipers were different than 90-92 calipers? Good price, I'm going to pick up a set for my upgrade.![]()
id guess so
Good price, Autozone has calipers for the same price, but they're not Ford NOS pieces.
yeah i read that, but nowhere in the description does it say includes pads or anything else included with a loaded caliper...
Except Autozone probably gets $125 for EACH caliper. They are selling the pair for $125.
And yes they are fully loaded. Calipers, mounts, slides, pads, the whole deal. I just put them on my car last week.
The only difference between the 89 and 90-92 calipers is the piston. 89 had phenloic and 90-92 had steel. They switched to steel because the phenolic had the possibility of melting.
How long is this sale for? I am in the middle of rear brakes right now, and just might get these instead.
Nope, I got my set of brand new loaded calipers from AZ last year (forgot the brand), they're $6x.xx each.
DDakRT is correct - I also purchased the remanufactured loaded caliper pair from AutoZone last fall - I paid $134.99 plus a $95.00 core charge and tax.
But that's not ture though.With the SHOBros deal, you are getting two brand new OEM Ford loaded calipers for the price of one rebuilt caliper. Even at the price I just paid before the sale, it was a no brainer over a pair of remans.
The only difference between the 89 and 90-92 calipers is the piston. 89 had phenolic and 90-92 had steel. They switched to steel because the phenolic had the possibility of melting.
Uhmmm..... No, that's not correct. All the rear calipers has steel or aluminum pistons. That's the only way the e-brake could work. No way would a phenolic piston take a threaded actuator.
The '89 SHO's had tapered roller bearings and did not have ABS and as a result, they had a slightly different offset in the rotor. Actually, you could use front rotors on the back of an '89 (with a little creative shimming of the caliper bracket). So these are not a direct bolt-on for an '89.
*looks at the set next to him* You've gotta be kidding......I never paid the core charges as I gave them a set of cores at the time. I don't get why core charges matter, even if you paid it you're going to get your money back either way, so the point is moot.
