BlackonBlack89
OK well after working for muiltiple nights past 12 to get this thing running and fixing the little promblems, I think most of them are fixed. However after driving it around tonight for less than 10 miles it destoryed the belt. I noticed it before that it was fraying but did not see anything touching it.
The belt seems to slowly eat away at one side. Closest to the engine. Pulled over to check it and there was still 5 ribs left. At this point knew it was a problem as the gap switched sides (fender side) After another couple miles it finally gave up. Looked like it made it to 3 ribs.
I think the alt UDP may be causing the problem. Anyone have expirence with this??? I noticed later that it was rubbing a little on the bracket by the 2 bottom bolts as the p/c is gone. Going to address this next but do not wanna waste another 30 for a belt, just to have it shredded again if its not the problem.
Anyone else have any problems with this?? soultion or things to check???? TIA.
anyways the car runs great, while it was running. I was surpirsed how soon its actually in boost.....at 3500 it was at 2-3. Man its a totally different car. driving home w/o the s/c the car felt so slow. Anyways hopefully this will be the last of the kinks to get ironed out. After this I am going to install the WBo2.....makes me nervous w/ out it.
That long bolt on the bottom was such a PITA to get lined up!!!!
