shobikes
So I finally did it. I got the GTP arms to replace the silly stock stamped units with the built-in rattle. Of course I went headlong into the job without consulting the Forum, 'cause they just looked so cool. I did shorten them 1/2" each, by cutting 1/4" off every threaded end, and the car has since been aligned. My rattles from back there are mostly gone. Everything went swimmingly EXCEPT:
How important is the placement and adjustment of the brake-biasing valve actuator? I removed the mount from the stock arm, and hammer-formed it to fit around the GTP arm, then randomly drilled a hole for the self-tapping screw that held it in place on the stock arm, after eyeballing it. No joy. I had to re-eyeball it once I had it in place, and relocate the mount, drilling another hole in my new lower control arm. My engineering background tells me the holes are in a non-stressed part of the arm, but I still hated drilling it, TWICE. Oh well- it's done, and SEEMS to be functioning, but I can't find any verbage on adjustment of this device. Can anybody give me some direction? I'd like to get it right, then tack-weld it there, 'cause I don't wholly trust the little screw.
