revhardSHO
Odd issue on the new 89...
The tranny, which was recently re-built is making a rythmic, very slight squiking, knocking noise. Its not adible unless your ear is down by the drivers side wheel. Doesnt sound metallic. Its hard to say if the sound changes with rpm, due to the fact that it cant be heard above idle. Depressing the clutch does not make a difference. The noise seems not to effect drivability in any way, shifts much better (smoother) than the other 89 and doesnt grind at high rpms. Fluid level is good...
i listened to the other 89 with 110k on the tranny it it does not make this noise. Could this be a bearing preload clearance issue?
