I just bought an 89 sho and when i got it it had some hesitation when pressing the gas at idle not in gear, in gear and when accelerating when it hits 3500 or so rpm it seems to regain its power its almost as if it lurches below 3500 it also had a whining sound when accelerating like a turbo sound building up. its not the clutch thats doing the lurching cause there is no rpm increase when the rpm increases the car speeds up. i know the front motor mount is bad there is a little bit of oil in the front 3 plugs i dont know about the back ones my fuel filter and air filter were changed there are no knocks from the engine at all when it grabs it really has lots of powerr but sometimes it drives like a normal car. I will changed the plugs and plug seals and wires and even the tapet cover gasket if needed maybe even the o2 sensors if needed and as far as the tps but after this i dont know what to do other than maybe check the fuel pressure or egr valve maybe get it plugged in and look for codes (oh btw the whining sound is coming from the pully area doesnt sound like too big of a deal but there is also a missing sound not very loud at low rpm kind of a sputter once i give her more gas its fine)
well now i started my car to go grab lunch at work and it runs like a top purrs like a kitten a small kitten
it has power equivalent to a 89 turbo lebaron and it actually still sputters a very very little bit when starting off in first but after that its very smooth i think it retimed itself to a lower power setting i dont know wierd eh?
