Running wires from engine to passenger comparment
ArrestMeRedSHO
S. Windsor, CT
I'm trying to install some PIAA 900 sereis combo fog and driving lights but I can't figure out where to run the wires fo the switch through the fire wall. Please help with suggestions on the best way to do this. I know you car audio guys do this a lot so it should be possible.
1993 MTX Red w/black int
SHO Shop Y-pipe and Flex pipe
Dynomax Catback
Underdrive Pulleys
80mm MAF
LPM
"Fishtank Lights"
PIAA Platinum Super White Bulbs from Frat Performance
CincySHO Floormats
Yokohama Avids 215/60/R16
TwiceSHOwn
Atlanta, Ga
Right behind your emergency brake pedal is a full inch gromet going through the firewall. Its only got like 1 wire coming through. Look at the edge of your carpeting for a black plug near the clutch.
red89SHO24v
Newport, RI
flounder -
how did you make out? i also used that grometted hole to run my foglights and stereo power cables. im curious as to how much difference those lights make - i might need to get a pair myself. hey, give me a call - what are you doin next monday nite?
Jon Kenney's red '89 w/ 235k miles
6463734 9469 0130009D
"modified" cats, Flowmaster mufflers, Grizzly Street Clutch, Grizzly Paw throw-out bearing, 73mm MAF, solid-rod conversion, K&N filter, Eibach Springs, KYB struts, FPS adj. aluminum control arms, 17x7.5 Neeper Synchros, 235/45/ZR17 Toyo Proxes FZ4's, TQ limiters, reinforced subframe mounts, polyurethane bushings, KVR cross-drilled rotors and carbon-fibre pads, police grille, glowing Ford emblem, red interior neons, one phat stereo system
ArrestMeRedSHO
S. Windsor, CT
Kenney-
With luck I'll have the lights in by monday night soI can show you when I get to WOrcester. I've been draging ass on it because of the coolant leak. I didn't want install until I get the leak fixed. I have also not yet been able to remove the stock brackets, which is somthing I wanted to do.
Oh and for those interested I used the antenna wire opening as described by Bizzy in thread of the same name under Electrical Maintence.
Pete
RStalveyARFF
too many shos
Georgetown, MA
guys you have to let me know where the SHO hot-spot is in worcester. I should be back there in the end of January to dyno the SHO with the programmed LPM, and maybe a few other mods. See ya!
ArrestMeRedSHO
S. Windsor, CT
I don't know if you've seen it in other posts but we've mentioned before there are usually four or more at our fraternity house on weekends, that's one place where you'll fnd people to talk SHOs.
thatSHOguy101
