How do I run wires from engine into the passenger compartment?
ArrestMeRedSHO
S. Windsor, CT
I'm trying to install some PIAA 900 sereis combo fog and driving lights but I can't figure out where to run the wires fo the switch through the fire wall. Please help with suggestions on the best way to do this. I know you car audio guys do this a lot so it should be possible.
1993 MTX Red w/black int
SHO Shop Y-pipe and Flex pipe
Dynomax Catback
Underdrive Pulleys
80mm MAF
LPM
"Fishtank Lights"
PIAA Platinum Super White Bulbs from Frat Performance
CincySHO Floormats
Yokohama Avids 215/60/R16
Bizzy
This is how I did mine. There is a hole where the antenna cable runs thu and I just got into there and ran it thru to behind the glove compartment. If you take the splash guard out of your passenger side front wheel well you'll see it. It's large enough to pass the cable thru. It was the easiest way I could think of without drilling another new hole in the fire wall. Hope this helps.
Edit: BTW, from the engine compartment there is a small hole that you can pass the cable thru to get to the inside of the wheel well. It's easiest to find if you take a flashlight and shine it up thru the wheel well. Follow the light and you'll do fine.
Proud to be an American!
Beth
'91 Plus MTX, Mostly stock
K&N Filter, Coneless
Colgan Custom Bra
Racing Series Driving Lights
Mods in the works
Many items on wish list!
[This message has been edited by Bizzy (edited 12-22-2001).]
RickieFrat
La Cosa Nostra
State of Corruption - RI
Ya know ... never thought of using that hole for the antenna. There is ruber gromet above the steering shaft. That is where my Amp wire is located. Hope this helps.
1992 TAURUS SHO
Sig Pic By SHOTIME (THX)
MORE INFO AND PICS
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
FRAT'S PERFORMANCE.COM
Your One Stop Source For ALL Your Audio Needs
Always use a rubber grommet at the *********** to prevent wear and shorting of the wires.
Scott
ArrestMeRedSHO
S. Windsor, CT
Bizzy you idea worked great, I never would have thought of that on my own. Now I just need o settle on a spot to mount the switch.
Thanks,
Pete
Bizzy
Glad I could help. Finally I gave a good idea that was useful. Enjoy!
Merry Christmas!
Beth
Colgan Custom Bra
Mods in the works
Satchmoz
