Original owner selling white/tan 1995 5MT
morebhp
Atlanta, GA
1995 SHO 5MT
White/Tan All Leather
VIN: 1FALP54Y4SA235302
Current Mileage: 137,600
Asking $3800
For sale by original owner. This has been my daily driver since February of 1995. It has no dings of any sort. It has never been hit or repainted. Exterior is 100% original. The only blemishes on the exterior are primarily weathering of some of the black trim pieces. Down by the right side fog light are a few hairline fractures in the paint which have been there about 15 years. I am a car snob. It has ALWAYS been garaged. You WILL NOT be disappointed if you see this car in person.
Interior is excellent. The leather is 21 years old and shows some age with creasing and wrinkling. There are NO rips in the leather. It’s just worn a bit. No interior parts are missing. All buttons and knobs are intact. The foam backing of the headliner started to disintegrate about 5 years ago. I simply trimmed the lose material and it’s barely noticeable to anyone but rear seat passengers.
You likely will not find an SHO in better condition. This is a rare one. I have maintained it but it has not been modified and tampered with. Only the exhaust parts are aftermarket except for the K&N air filter.
History
  • The engine has never been opened up. I'll be honest, it does need a gasket job. It has the typical oil leaks but otherwise the engine has no issues whatsoever. It has never needed internal work. If you are looking for an unmolested SHO, this is it.
  • Oil was changed by ME with quality oil and filter every 3000-5000 miles.
  • A/C system was rebuilt (except for compressor) in 2007. It works like new today and hasn’t needed a single recharge since the initial charge in 2007 after the rebuild.
  • It is running on its 2nd clutch. Original was replace at 20K miles. While it has 115K miles on it, it does not slip and shows no signs of needing replacement. It has an aftermarket “Bear Claw” throw-out bearing.
  • Y-pipe was replaced with Magnaflow in 2007.
  • Cat-back was replaced in 2007 with Walker Dynomax.
  • Brakes have been recently redone. Rear calipers have been replaced.
  • Radiator has been replaced a few times. Currently this one is not leaking.
  • Fuel pump was replaced in 2011.
  • Currently has fairly new Taylor plug wires.
  • Headlights (the lenses) and turn signals were replaced a few years back. They are still clear and new looking.
Mechanical Status
  • This car has been my daily driver until about 2 weeks ago. It has NO MAJOR PROBLEMS mechanically. The most annoying thing is oil leaks. It needs a gasket job. It takes about one additional quart every 3000 miles. It just leaks oil. It doesn't burn it.
  • Everything works except the following:
    • Power antenna doesn’t go down.
    • Factory CD player has been disconnected from the head unit because on hot days, it thinks there’s a CD in it to play and it cuts the radio in and out for 10 minutes.
  • The JBL Audio system works fine except for the CD player mentioned above.
  • Currently has Yokohama Avid Envigor tires with about 15K miles on them. You will not need to replace the tires for a while.
  • All 4 original floor mats are clean and in great shape.
  • A like-new Colgan bra comes with purchase.
I'm in the far north metro of Atlanta. Email if you want to make an appointment to see and drive the car. I can provide my phone # upon request.
Email Mark at [email protected]
Shawny
S.H.O.NY BADGER
Southeast M.I.
1995 SHO 5MT
Asking $3800
History
Mechanical Status
Is vehicle still for sale?
Brumfield780
