Running rough, computer tested.
bruce988jl
Belmont, MA
alright so as some of you may know my SHO has been running really bad. It dies sometimes randomly, and the idle is at 400 rpms all the time and it sounds like a heavy smoker trying to run a mile when accelerating. I hooked it up to a computer and drove around while the mechanic looked for codes. First off he noticed that the TCC SOL was at %0 for a while. And secondly there seems to be oil leaking from the bottom of my camshaft position sensor. Other than by replacing that sensor is there a way to stop the leak? a gasket or o-ring or anything?
As for codes.. all we found was SNAP THROTTLE, i forget the code number, but it kept giving us that code, even when the car's CEL wasn't on. Any ideas?
Thanks in advance,
Jason Lee
93MTXSHO_STUD
lubbock, TX
Thanks in advance,
Jason Lee
just did my seals today. shophoniex has alot od good pictures i highly recommend it. just buy one seal at advance for 5 bucks and use a scratch al and hammer a hole in the metal housing and get a heavy duty dental pick and get it out. DONT SCRATCH THE CAMSHAFT or you'll be F'ed
