running rich
SHOman247
michigan
ok what could be causing my sho to run rich. You can smell gas really bad out the tail pipe when at idle and in the car when i rev it up. Plus lately i have gotten some pretty crappy gas mileage. So what might be causing it to run rich and how can i fix it? I have no leaks that i can find. anyone else have this problem?
SHOman247
michigan
i haven't had a CE light come on yet but i will be doing scan of stored codes this weekend. would a KOER test detect that?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Possibly, but it may not depending on how bad the Oxygen sensor is. Sometimes they get lazy but wont throw a code.
Mr Anonymous
Tire Wall
Where's your temp gauge reading? If the car isn't warming sufficiently due to a stuck-open t-stat, your car will remain in open-loop, full-rich mode. A failing ECT sensor may also be the culprit. First start by reading your codes.
SHOman247
michigan
95% of the time it stays at 195 range but once in a great while it will climb to 210 and stay there then go back to 195 and this is not b/c the fan kicks on or anything
SHOman247
michigan
nope and yes...i have a fuel pressure gauge and it's always were it supposed to be in terms of fuel pressure
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
In that case, I would probably clean the MAF if you havent already (electrical contact cleaner, any auto Parts store) and replace the oxygen sensors (autozone, $38.99 each for the Bosch).
