tmielnichuk
Running rich, can't pull codes Update!
Hi everyone,
Here's the details:
89 SHO will start when cold, but will run extremely rough and runs very rich. So rich that it creates black spots on the pavement under the tailpipes. It is NOT burning oil. If I tap the gas lightly it stumbles and almost dies. If I try to move the car it will stumble and stall out. The car will run ok after warming up for about five minutes. If it is at idle and I tap the gas after it has warmed up the revs will dip THEN rise as usual.
I tried to pull the codes but the computer refuses to give up the goods. No CEL and it won't even run the tests. No cycling of the sensors\valves at all. The bulb isn't burn out on the CEL. I can't run either the KOER or KOEO test.
What would make it run so rich? Is the ECU screwed? Would the car even run with a "fried" computer? Are the O2 sensors screwed? Could this be a knock sensor problem?
No-one in this area seems to have a SHO that I can borrow an ECU from to swap it temporarily.
Any thoughts on how to trouble shoot this problem would be great.
Here is a list of parts that have been replaced recently:
Throttle position sensor
Water Pump
Crank position sensor
Water temp senders
Fuel Pump
Fuel Filter
alternator
starter motor (Didn't do the solenoid though)
plugs
wires
valve cover gaskets and plug well seals
IAB
probably some other little things that I can't remember.
I do know that the relay for the rad fan is conked out so I wired the fan to a rocker switch in the dash. Would the rest of that relay unit be causing any problems if the other relays are damaged?
Sorry for the long post but I am stumped.
Thanks for all the help guys and girls!
Hi everyone,
Here's the details:
Water Pump
Water temp senders
Fuel Pump
Fuel Filter
alternator
plugs
wires
IAB
